ARM700 F1-31 Code
  • mikez
    • Oct 2012
    • 30
    ARM700 F1-31 Code
    Anybody ever run across an F1-31 code on an ARM700.
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: ARM700 F1-31 Code
    From the manual...
    Finisher saddle folding sensor
    trouble
    F1 31 Phenomenon Display Lamp
    Message
    Details Finisher saddle folding
    sensor trouble
    When the motor rotation
    speed (linear velocity) at
    every 200msec falls
    below the specified level.
    When moving to the
    home position, the home
    position sensor does not
    turn on within the
    specified time.
    When shifting from the
    home position to the lead
    edge, the home position
    sensor does not turn off
    within the specified time.
    Section Finisher
    Operation
    mode
    Note
    Case 1 Trouble
    position/
    Cause
    Sensor breakage
    Harness disconnection
    Console finisher control
    PWB trouble
    Remedy Use SIM 3-2 to check the
    sensor operation.
    I did the hard part and read the manual for you, now you can do the easy part and fix it!
    • mikez
      • Oct 2012
      • 30
      Thanks tips. I read the manual and checked all that sensors, motor, and board are all good. The Tech even replaced all the board and motor with working ones and changes sensors.
      • Akitu
        • Oct 2010
        • 2595
        Is your firmware as recent as possible? The error is basically describing the sensor is having some hanging issues, either in activation or deactivation. Did your tech test sensor responsiveness? Is the harness for the staple motor pinched anywhere? Has the copier PWB been replaced or just the finisher?
        • mikez
          • Oct 2012
          • 30
          Firmware up to date. The motor ended up blowing out the board. So we ordered a new board. When I took a look at it i noticed there was a gear moving funny took it off and long behold it was stripped a little bit. Finisher working good now. Thanks a lot.
