Sharpdesk, where to get it
  • jw4444
    • Aug 2025
    Maybe a dumb question, but where where/how does one get Sharpdesk (for a Sharp AR-M237). Can't find it in Sharpusa.com's download section.
    Thanks.
  • harleyrider
    • Oct 2011
    • 348
    Re: Sharpdesk, where to get it
    Check on sharp idnc website
    • jw4444
      Thanks but I'm not affiliated with a Sharp dealer, just an IT guy for a company with a couple of Shap printer/Fax machines.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        There should have been a copy of Sharpdesk that came with your copier, however at this point it would be outdated and incompatible with Windows 7. Sharpdesk 3.3 was the compatibility update to Win7. Else it can be downloaded from Sharp's FTP website (which, as a non-tech, you may not have access to).
        Best bet would be to call your local Sharp dealer and see if they may be able to assist you.
        • jw4444
          K. Ill try that (the dealer).. That's probably where the vers they're using on their older machines came from. I just thought it woudl be something you could download from their website.
          FWIW, what is Sharp's FTP site?
          • Akitu
            • Oct 2010
            • 2595
            Unfortunately not. I just spent the better part of a half hour looking for a customer. Only place I could find it was on the ftp site.
            Without the credentials, there's no harm in giving it out I suppose.
            ftp://service.sharp.ca
            Typically for trained service techs, feel free to sit there guessing at passwords and usernames for half of eternity.
            • jw4444
              I was just gonna try 'anonymous' & 'guest' w no pw. Didnt work. Ill try the dealer next week. Thanks alot for your help.
              John
              • lky1978
                • Mar 2009
                • 483
                can you wait? i can upload to dropbox if you need. But i only can do it when i work on monday.have a nice sunday.
                • bilyahn
                  • Dec 2006
                  • 1470
                  Try this link. Used to be version 3.2 not sure what version is there now. You will need a valid serial number to use this software should be with your copier paperwork.
                  Good luck.
                  Bil
                  • oldrn
                    • 166
                    For my own information and depending on the answer, maybe to help out jw4444, will the AR-M237 scan without Sharpdesk? Can you scan to a file or to e-mail without using Sharpdesk on this model or series? I asked this question awhile back but wasn't real sure if I understood the answer correctly.
                    • CorbinDallas
                      • Mar 2012
                      • 56
                      SharpDesk
                      SharpDesk requires a licence to install or upgrade. If you do not have you license (per client) you cannot install. It is not required to scan. Email and ftp work with most models that support scanning.
                      • kthiessen
                        • Sep 2012
                        • 10
                        sharp.ca
                        customer support
                        product downloads
                        drivers
                        imagers
                        mx2640n
                        one of the first results
                        • tkrumrai
                          • Mar 2013
                          • 8
                          SharpDesk is a licensed software that comes (1) per unit. (ONE license per unit). More licenses can always be purchased. It is a scan to desktop solution. Comes in handy for scanning color docs...also has a very limited OCR (optical character resolution) feature and a Composer feature. OCR feature takes a document and converts it into an editable document. Kind of a clunky Adobe knockoff...works fine with just text...but ANY pics or lines confuse things.
                          • koaslosa
                            • Apr 2011
                            • 28
                            Sharpdesk Software | Sharp Applications | MFPs | SHARP
                            • guitar9199
                              • Sep 2016
                              • 1100
                              The product brochure says for scanning, you'll need the AR-NS2 Network Scanning Kit (optional), so if you were scanning before I'm guessing you've already got that installed.
                              SMB desktop scan requires the Sharpdesk software, but scan to FTP or email does not. I have a sneaking suspicion that scan to email might be a little touchy as well....with the age of the machine, I'm not sure it supports SSL.
                              Good luck.
