Hello,
On a customer's MX-4101N occasionally the image of scanned sheets fed through the top document feeder will shift downwards and to the right slightly. It also looks as if there is a faint line generated across the wide top margin. I've tried cleaning the glass, but even when I go on site I cannot generate the issue. Is there a calibration simulation or a setting to turn down the scanner sensitivity? Does anyone have any other suggestions?
Thank you!
Thank you!
