MX-M452N Error Code F2-40
  • vlad_
    • Jul 2008
    • 98
    [Error Code] MX-M452N Error Code F2-40
    Good afternoon colleagues.
    Met a problem F2-40
    The device goes on alert. When you press the START button, the sheet stays on the sensor PPD2. Message-F2-40
    In the "DV" a lot of toner
    Firmware is version 1.02
    Sim 44-06 - error.
    The value of simulation (25-1) the value of 27
    I produced these steps:
    1. Replacing DV
    2. Cleaning ATC sensor
    3. Cleaning Process sensor (Transfer unit)
    4. Replacing the toner cartridge. (both old and new original cartridges SHARP)
    5. Performing simulation 25-2 (the value was equal to 100).
    6. Performing simulations 24-5
    7. Firmware is updated to version 1.04
    The result - an error F2-40 was lost. The device works.
    My fear is that the error appears again after some time.
    When all the action, I did not find obvious causes of the problem. The sensors were not very dirty.
    What experiences have you had, with the appearance of this error?
    What steps I had to do more?
    The scanned image of a leaf of the report in the file.
    Thank you.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: MX-M452N Error Code F2-40
    Has the MFP been moved with the toner cartridge installed? We have had the F2-40 codes (usually over toned) show up before we started removing the cartridge when delivering machine.
    • vlad_
      • Jul 2008
      • 98
      No. MFP will not tolerated and not transported.
      • mojorolla
        The Wolf
        • 2604
        Check the toner feed tube for hardened toner. Sharps new toner loves to clump and dust, causing an array of F2-xx codes.
        • WilliamTucker
          • Jul 2012
          • 38
          Use sim 7-1 disable dv check and run about 50 sky shots and check 25-2 . Should take care of it
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • vlad_
              • Jul 2008
              • 98
              Thank you.
              • igi
                • 1507
                yep i will try that too
                ps how is Ginormica doing
                • mojorolla
                  The Wolf
                  • 2604
                  I believe you meant 25-1. 25-2 should only be run with fresh dv material.
