firmware
  • spacedust
    spamanamamammmmm
    • 47
    firmware
    Hi all
    just posted same on kyocera, but whats the largest sharp take for firmware upgrades using usb flash, i had a 2gb which was fine but only have 4gb now and want to check before causing myself a problem.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: firmware
    I use a 16GB USB flash drive, which seems to work fine.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Re: firmware
      The older MXM350/450s would have a hard limit of 2GB capacity on any flash drive being used for f/w updates (prior to another f/w update it was restricted to 1GB) in FAT16 format.
      New machines have no such capacities to my knowledge and will read any drive formatted in FAT32.
      • spacedust
        spamanamamammmmm
        • 47
        Re: firmware
        Hi thanks, i will try a 4gb.
        • bilyahn
          • Dec 2006
          • 1470
          Re: firmware
          Have had some issues with USB larger than 2GB. You just have to try them out to see if they will work. What I found interesting was I would have a USB drive work on one copier but not on another in the same series of machines! Very annoying. That's why I have several with me at all times.
          Good luck.
          Bil
          Almost forgot. If you're having a problem seeing the sfu file in a folder on your USB drive try moving the file to the root directory. Have come across this problem several times.
