Single color adjustment on Sharp 4101
  • GR81
    • Jun 2012
    • 45
    I have a customer that has a certain color blue 26.16.162
    They want just this blue adjusted and no other color.
    I can not find the proceedure for this.
    Any help would be greatly appreciated.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Single color adjustment on Sharp 4101
    Check the operator's guide that is located on the machines web interface or the paperwork that came with the machine. It will get you to the settings that you need to adjust in system settings. If that doesn't work then you will need to enter simulation mode and manually adjust the color to what they want (not recommended unless you are very experienced with adjusting color). If that is a registered Pantone color then there are more steps involved to get it to reproduce that color (you can get it close but it will never be exact without it).
    Good luck
    Bil
    • mojorolla
      The Wolf
      • 2583
      Pantone is the only way to go in this scenario. Load the Pantone ICC profile into the machine. When a print job is sent that contains Pantone, the machine will render it according to that specific profile.
