Hi all just wondering if any body has come up with the same problem and had a fix! mx4111n with a mx-fn10 finisher first sheet would come through and side jogger will push paper over than when the next sheet comes through than it throws a jam,going into sim 22-3 jams log it shows FGMJ but i cannot find this error code nor is it listed on any sharp service bulletins.I dont know if some how its gone out of timing as i haven't come across this problem before.Only way to get around it to get the customer going was to disconnect the finisher and remove centre paper transport section and plate so paper exit shift doesn't chatter and throw a code.Cheers!
