New color Mfp's MX2610 > 5112
  • Kris@Bkm
    • Jul 2025
    Hello all, i'm new to this forum, so, i'm a sharp technician from belgium, local dealer, 15years experians. My first post here, so, like the title say's: we replaced 7mfp's on the same custumor, automotive branche. (mx2610, MX3640, two MX5112, three MXM363 BW). Now, we have a couple times a day, that al "color mfp's" freezes in the network, we have to reboot the mfp's to put them back online. The black and white one's dont have this problem. We disabled snmp on both mfp's and server ports, no result, we put a "new" fresh MX2640 on the network, in an other IP range (DHCP), not connected to a server, no config at all, only IP, it goes offline as well with the rest of the color MFP's. When i say off line, it is also not possible to connect direct with the laptop on lan card, we have to reboot them before they come visible again in the network. i put an old MX3501 on the network, it works fine, does not go offline with the rest, so the problems is only on the new COLOR mfp's. So, i hope there is someone out there who have the same problem in the past, because it is a hard one.... I also tried 55:3 en set the lan ports to 10mB and half duplex, no result. Wire sharp captures arent telling anything neither... Anyone? Thanks in advanced, Regars, Kris.
  • Nachoman4life
    • Oct 2007
    • 212
    Re: New color Mfp's MX2610 > 5112
    the newer firmware's have taken care of most of the lockups, stalls, and unresponsiveness.
    Where the heck is my spring hook?
    • Kris@Bkm
      I forgot to say in my post that received version 8 from sharp europe for the 5112 and a newer version for the 3640. (1.02?)
      There is something on that network that makes the new color MFP's lock up somehow...the older ones dont have this problem..
      So, for me its a mixed problem: Network/ mfp's (and only new colors...)
      Thanks for thinking with me!
      • mansart
        • 852
        Go into web interface and then to PORTS section and disable everything not being used. I just had very similar situation and disabling Port 50001 (tandem copy) fixed problem
        • Kris@Bkm
          I wil def. do this first thing on monday (today holiday )
          Thanks in advanced, and keep you posted!
          Regard, Kris
          • Kris@Bkm
            I did switch of tanden copy (server en client), stil lock-ups on all new colors. i switched everything off on a test mfp, exept html, still locking up with all te rest. Help...
            • mojorolla
              The Wolf
              • 2605
              Using the built in Device Account mode by chance...?
              • Kris@Bkm
                No?
