I have a mx 700 customer says its setup for VPN and wants to know if it can be changed to MTU don't know what there talking about any body help thank you
mx 700 connectivity
Re: mx 700 connectivity
Their IT person probably wants to decrease the MTU size because of the VPN. The MTU is the maximum transmission unit. The default is 1500 for most NICs and normal uses. However, the VPN adds data to the packet(increases the size) and this can make the total packet greater than 1500 bytes. This can lead to packet fragmentation and can harm network performance (and some routers may actually just drop larger packets). To combat this, the IT person probably wants to drop the MTU to about 1400 bytes, which provides room for the VPN to add its information without exceeding the standard 1500 byte packet size.HTML Code:Sorry, but the editor won't let me start a new paragraph, so this is my way to break up the reply.
I took a quick look at the older style web interface and I didn't see a setting to change the MTU there either. Your best bet may be to call Sharp support and see if there is a soft switch setting to change the MTU size.Comment
