Hi there i have a sharp mxm-850 with an attatched mxlcx6 lcc but the problem is is that the copier does not recognise the lcc....it hasnt been plugged in or out with power on and there is a red led blinking on the board of the lcc.....any ideas please
Sharp mxm-850
Re: Sharp mxm-850
Make sure the LCC is firmly attached and the locking screw is in the correct position.
I've done fairly similarly stupid things with LCCs on other machines, and at times it has (at a glance) appeared to be properly seated, but wouldn't read. Turns out the glance was too quick and it was in fact, not.Cthulhu for president! Why settle for the lesser evil? -
Re: Sharp mxm-850
Paul@justmanuals.comComment
Re: Sharp mxm-850
In diagnostics the tray would lift, but would not otherwise in the copy mode.
From the install manual:
"* If the screw is tight, the tray will not be locked.""You can't trust your eyes, if your mind is out of focus" --Comment
Re: Sharp mxm-850
Check the secondary power cable. In all regions other than North America, the MXM850 has 2 power cables... One for the engine, one for any peripheral devices (LCC, finisher etc). Its very easy for the secondary power cable to be turned off, leaving only the engine detected and shown on the panel. Even with a flashing light on the LCC PWB, if the secondary power is off, there'll be no peripheral devices shown.
Check 22-10 to see if the LCC is detected.
This only occurs on the 850, as the 950/1100 share a single power supply.Cthulhu for president! Why settle for the lesser evil?Comment
