Part Number
+ More Options
Posts
  • Madnhain
    • Dec 2012
    • 148
    Part Number
    Here's an easy one for y'all...
    I need the part number for the "paper feed unit 2" for an MX-DEX3 (maybe it's a 4... doesn't matter... ) anywho, I need the full assembly, but the parts manual does not have the full assembly (weird) only all the itty bitty parts, and I don't really want to order all the parts and put the puzzle together, that just doesn't sound like a good time. This is for an MX-4501N... the parts guide for the 4501 has a similar assembly for drawer 1(with part number) though there are enough differences that I don't trust that it will work. To clarify, it's the paper feed assembly in the top drawer of the DEX unit on a 4501, that contains the switch, pickup and feed rollers.
    Cheers
  • Silvertoast
    • Feb 2010
    • 270
    Re: Part Number
    not available as a unit
    • Madnhain
      • Dec 2012
      • 148
      Re: Part Number
      Well, that is moderately calamitous.
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: Part Number
        Cheers
        You can order the PF assembly from the main engine, and with "some minor changes/swapping parts & removing others" you'll have a working DEX PF unit.
        Or, you can strip a PF unit from a used machine ready for the re-recyclers.
        • Silvertoast
          • Feb 2010
          • 270
          Re: Part Number
          ^^^^this^^^
          • Madnhain
            • Dec 2012
            • 148
            Re: Part Number
            All great ideas, unfortunately we Recently lost all out inventory, and no longer have a pile of old machines to yank parts off of.
            The location of this customer is about 2 hours away, I was short on time and there was obviously something broken inside the unit, I figured I'd just order a new assembly instead of taking it apart to see what was broken.. (oops) I'm heading back up there today for a different service call and will check to see what is actually broken and order the appropriate part(s).
            It doesn't make much sense that they would have a PF for the main unit but not a DEX... Sharp, in all their infinite wisdom, surely has their reasons.
