No black prints from Sharp Mx4501n
  • Walks
    • Nov 2012
    • 9
    [Misc] No black prints from Sharp Mx4501n
    Ok, My Sharp MX4501n does not print black. A self test shows that the black is missing. I changed the black drum but this does not solve the problem. Any suggestions would be welcomed.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: No black prints from Sharp Mx4501n
    Check your PTB, and laser shutter for Blk to see if it's opening.
    • Silvertoast
      • Feb 2010
      • 270
      possibly the roller for blk in the transfer unit isnt lifting
      • Walks
        • Nov 2012
        • 9
        Thanks Zootech. The PTB has signs of Magenta toner but not black. How do I identify and check the LSU shutter for Black? I am not seeing the shutter on the service manual. There is however mention of the shutter solenoid.
        • Walks
          • Nov 2012
          • 9
          If this is so should I replace the PTB then or is there a way I can verify this? - i.e that the roller for black not lifting.
          • ZOOTECH
            • 3374
            Remove PTB, DRs, and DV units - the shutters are on the bottom of that area.
            • ZOOTECH
              • 3374
              TC 6 (load test) should rotate between "free, Blk, and color".
              • Walks
                • Nov 2012
                • 9
                I believe you are referring to SIM 6-3. As soon as I run this I would let you know. I may not respond immediately as I would not be revisiting this unit until next week.
                • Walks
                  • Nov 2012
                  • 9
                  Ok. I shall check the shutter. Apart from physical examination, is there a simulation I can run to check shutter operation?
                  • ZOOTECH
                    • 3374
                    With the units mentioned above removed, run TC 6-1 to initiate LSUSS. You should see the shutters open fully, if not, it's possible that the solenoid is dirty and not pulling the blk shutter open all the way or the spring on the shutter
                    is not allowing the shutter to open. You can remove that spring and see if that helps, or just switch the yellow and black shutters to see what happens.
                    • Walks
                      • Nov 2012
                      • 9
                      Thanks again Zootech. I would let you know what happens after executing this. Give me one week when I would be able to return to his unit.
