Re: Flash Copy on MX-M450N
Well, that is interesting. I went ahead and changed the filename back to this again and switched the DIP to read from the rear USB instead of the front (I am desperate at this point). It now at least changed to "checking USB device", but has said that for some time now. I am going to let it run until I get back from lunch. I am thinking if it fails I will rename it back to the original filename and try again. I at least have some hope now that I can do it this way, instead of swapping ROMs and boards from the used machine. **fingers crossed**
Thanks for all your help so far
