Jupiter 3 Admin Reset
  • ZOOTECH
    Senior member of CRS
    • 3375
    With a DSK installed, how does one reset Admin password to default? TC 24-30 / 31 is not showing with DSK, and I could not find those 'barely visible' switches like the newer Virgo machines.
    Cannot do a NIC reset, because Network Settings requires logging in as Admin. Cannot access web page to change password because you have to login as Admin. Is this one of those cases where
    the EEPROMs have to be sent in for reprogramming by Sharp?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: Jupiter 3 Admin Reset
    I think this may be related to other posts, HDD format may reset admin password.
    • ZOOTECH
      • 3375
      Yes, that could work, as long as we're able to clone and backup any data saved first.
      Thanks Akitu...(and I see you used that qualifying word "may")
      • Akitu
        • Oct 2010
        • 2595
        Data backups can be executed from the service webpage. (IP address of copier)/service_login.html
