MXFNX9 SQUEAKS
  • gwaddle
    • May 2009
    • 782
    MXFNX9 SQUEAKS
    I searched the forum and didn't find a definitive answer to this. Has anyone found a permanent fix for squeaks in this finisher? I've taken them apart, cleaned and lubed bushings and whatever else moves. It takes care of it for a while and then they come back. It's just a bit annoying. Thanks.
    I know I should be ashamed of myself. Strangely though, I am not.
  • harleyrider
    • Oct 2011
    • 348
    Re: MXFNX9 SQUEAKS
    I like you have not found a good fix. It seems like about 50% of them squeak when I show up for a simple call and I spend more time on this than the original call.
    • mojorolla
      The Wolf
      • 2626
      Re: MXFNX9 SQUEAKS
      They all make noise. I have long since stopped taking them apart as it is labor intensive and the noise will always come back. I usually remove the finisher, remove the top cover, pull out the 3in1 oil, and lube accordingly. Be sure to run 50-100 copies as the oil will show up on the pages running through at first.
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        Re: MXFNX9 SQUEAKS
        I've heard from somewhere that the way to eliminate the squeak permanently was to replace every single piece of plastic, mylar or roller. Way too labour intensive, my solution thus far has been to replace the squeaky finisher with a non squeaky one until the customer can stand the noise no longer and wants a new machine.
        • gwaddle
          • May 2009
          • 782
          Re: MXFNX9 SQUEAKS
          Found a fix that worked on two different ones yesterday. Pull the top cover and lube the four rollers attached to it and also bend them down just a bit to add a little more pressure. Worked on both machines. I got an email confirming this fix from a friend this morning. Thanks for the responses.
          • MHeon71
            • Oct 2008
            • 489
            Re: MXFNX9 SQUEAKS
            I have used this bulletin to fix the squeeking, MFP-TB-529. They are very easy to change and they have solved the majority of my squeeking issues.
            Parts - Qty 2 - 0CW4141K05103, Qty 2 - 0CW4141K05203
            • Tech2002
              • Aug 2008
              • 334
              Re: MXFNX9 SQUEAKS
              Can you direct me to the exact part you are referring to? I did the lube think with a Spray - 2-26 Plastic Safe Multi Purpose Precision Lubricant - got this at The Home Depot - Works just like they say.
              • Tech2002
                • Aug 2008
                • 334
                Re: MXFNX9 SQUEAKS
                Appreciate all the input from everyone - I am going to try the info from the Sharp Tech Tip - MFP-TB-529 - Thanks to all.
