mx-m363 e7-14 error
  • sharptech1
    • Oct 2011
    • 163
    mx-m363 e7-14 error
    After replacing the updated SCU, CCD, and harness, I am still getting this error code. After becoming aware of all the tech pubs about this, I am wondering if I messed up by replacing one part at a time instead of all three as a set. Anyone ever seen this before?
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: mx-m363 e7-14 error
    Manual says change SCU PWB. Not sure why you did the PWB or harness, nor am I seeing any bulletins related to this particular error code. My guess is you changed the SCU PWB but not the ROM chip seated in the board?
    • mojorolla
      The Wolf
      • 2627
      You need the updated lens, CCD harness, and SCU pwb as a set. You also need firmware 0200j3 or higher for the new SCU pwb to work. The update must be done BEFORE the lens and harness are installed.
      • Akitu
        • Oct 2010
        • 2595
        Much better answer than my own. I would follow Mojo's advice.
