Sharp MXM350N U2-11?
  • skibum
    Independent Service Tech
    • 234
    Has anyone seen this code and can help me. Thanks in advance.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp MXM350N U2-11?
    Checksum error. Normally you can just reset with sim 16 and it won't return:
    U2 11 Content Counter check sum error (ICU)
    Detail Counter data area check sum error
    Cause EEPROM troubleControl circuit trouble by noiseICU PWB EEPROM access circuittrouble
    Check andremedy
    Check that EEPROM is properlyinserted.Save the counter/adjustment valueswith the DIAG simulation.Use DIAG (SIM16) to cancel U2trouble.
    Replace the ICU PWB.
    Good luck.
    Bil
    • skibum
      • 234
      Thank you for replying. Where is the EEPROM located and how do you get into service mode (ex.. CRPC - ?)?
      • Akitu
        Legendary Frost Spec Tech
        • Oct 2010
        • 2595
        EEPROM is located on one of the boards, and if you aren't aware how to get into service mode I would suggest you purchase a manual from our friendly manual salesman or contact your local Sharp representative.
        • lky1978
          • Mar 2009
          • 483
          yes, Paul ll contact you soon
          • MHeon71
            • Oct 2008
            • 490
            If you replaced a board and started getting this code, you may have forgotten to switch the EEPROM with the original boards EEPROM. The EEPROM is an 8 pin chip.
