I have an ARM455 that gives a CE-03 when you do a scan to email. I checked the smtp settings and they are good. It passes a connection test on the web interface. We put the same info into a machine at the shop and it worked fine. The manual says that a CE-03 is specified server suspends response during transmission of image. I am pretty sure it is a network issue I just need to be able to tell there IT people what the problem is because they want to just blame the copier. Does anyone know what would cause the CE-03 code.
ARM455 scan to email problem
