Can anyone give me information about the different Sharp cables available for different model connections to vending machines. I need to hook up a Sharp machine (Ar-200 or Ar-275,ARM-237). Please advise on the cables and what models they are good for and how I can obtain them. Is there a Sharp part # for these or supply order number? Never dealt with coin ops. Your help is greatly appreciated. Frank/ActionPhotocopy
Sharp vending machine harnesses (d vend?) such as PG etc
Re: Sharp vending machine harnesses (d vend?) such as PG etc
Th AR-200 uses the DVENDPG, The AR-275 uses the DVENDLG. The AR-237 uses the DVENDAG.
I'm sorry I don't have the Sharp P/N for these.Jamex Tech Support: Saving the world one phone call at a time. -
You're welcome.
If you do get P/Ns from Sharp could ya let us know what they are?Jamex Tech Support: Saving the world one phone call at a time.Comment
See attached document for part numbers.Attached FilesComment
Thanks Don. It looks like there are product codes and not parts numbers as they are probably sold as supply items. I tried using the product codes on Sharp part entry but came up as invalid. I will try to order thru product code. FrankComment
