Sharp changed their driver website - GDI drivers
  • Smidge
    • Sep 2025
    I need to download the GDI drivers for the AR-M237 copier since it doesn't have the optional NIC expansion. Apparently, Sharp has changed their website and the GDI driver cannot be selected. Does anyone know where I may be able to get the 32bit and hopefully a 64bit version of these drivers for Windows 8? (Windows XP and 7 would be great too).
    Any suggestions would be greatly appreciated.
    Thank you
  • faxman28
    • 435
    Re: Sharp changed their driver website - GDI drivers
    do the google search on sharp service website , I ran into same problem yesterday. Saw that all the gdi drivers are no longer in the driver library. did a search on ar-m237 gdi and found the win7 64bit gdi driver.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Sharpusa does not seem to have the GDI/SPLC drivers for that series, I would assume likewise for similarly aged machines.
      Sharp.ca on the other hand, does in fact have the SPLC drivers. I routinely flop back and forth between the two depending on which one wants to work if I need to tell a customer how to get the drivers.
      • Smidge
        Perfect. That is exactly what I needed. Why they had to change it up the way they did is beyond me.
        Thank you for your help.
