FO-2080 Sharp pulls developer onto the transfer unit. Change DV DRUM R.Door, NO LUCK
  • CraigWells
    • Aug 2025
    I've seen the other thread about FO-2080 developer pull. So I've replaced the developer, drum, R. side door, TC unit. The high voltage checks normal. So it must be fixed by now... I WISH.
    Any thoughts out there.
  • lky1978
    • Mar 2009
    • 483
    How about developer cleaning seal? Main corona ?
    • lky1978
      • Mar 2009
      • 483
      How about developer cleaning seal and main grid?
      • CraigWells
        Re: FO-2080 Sharp pulls developer onto the transfer unit. Change DV DRUM R.Door, NO L
        Yep. By Drum & DV change I mean FO-55ND & DR (entire units) so I've cleaned house.
        • DavePo
          • Jul 2008
          • 305
          We are having same issue with the AR208. Even replaced HVU PWB. Still pulls developer. Not sure what else to try.
          • teklife256
            • Sep 2012
            • 164
            Hey all, Im working on a FO-2080 that is pulling dv. The dv is deposited on the paper in lines front to back at a frequency of a single revolution of the drum. The dv does makes it way to the transfer corona as well. Three weeks ago I replaced the toner/dv unit. At the time the problem seemed to be resolved until yesterday.
            The MC looks good and the drum looks good. Im headed back today to provide a loaner until I can sort it out.
            Ideas where I can go from here?
            • teklife256
              • Sep 2012
              • 164
              Fortunately, I was able to get the customer a loaner and brought the F0-2080 back to the shop for diagnosis. The toner/dev cartridge was replaced about three weeks and I just replaced the drum cartridge in the shop with a new unit. The problem seems to have been resolved but I wonder if there is an underlying issue. The drum cartridge looks like it has about 8500 clicks on it according to the machines meter.
              Any ideas? The last I want is to get a call back in few weeks for the return of the dev pull problem. With the machine in the shop it affords me some time to diagnose.
              • teklife256
                • Sep 2012
                • 164
                Just wanted to update that I resolved the issue by replacing the drum. While it looked brand new I was able to narrow it to down by process of elimination.
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  Thanks for the update! Not too terribly often there's a resolution posted so long after the thread dies.
