H2-02 on MX230FU1
  • Andypraeuner
    • Jun 2013
    • 35
    [Error Code] H2-02 on MX230FU1
    If anyone can point me in the right direction, I have replaced the upper roller thermoster, the lower roller thermoster, and the uncontact thermoster. I am getting this code every time on a new MX3110N that works just fine with its original fuser in it. I have checked all of the connections on these thermosters as well as any other connection in that area of the fuser. Since the machine works fine with its original fuser in it I figure I can rule out the need to replace the PCU PWB or the connector at the fusing section. I have 2 of these fusers with the same code H2-02, both have new belt and roller kit rebuilds if that is any help.
  • ZOOTECH
    Senior member of CRS
    • 3378
    Re: H2-02 on MX230FU1
    The MX3110N takes a MX-260FU1.
    • Akitu
      Legendary Frost Spec Tech
      • Oct 2010
      • 2595
      Where's that damn like button when you need it...
      • Andypraeuner
        • Jun 2013
        • 35
        OOOOOMGG thanx ZOOTECH for getting my mind and eyes back in focus.
        • mojorolla
          The Wolf
          • 2639
          DITTO!
          The same code happens when you put a 4111 fuser in a 5111.
