L4-12 sharp mxc 310
  • Danwood007
    • Feb 2013
    • 36
    L4-12 sharp mxc 310
    im getting error code L4-12 on a sharp mxc 310. Code relates to secondary transfer unit problem. Both the primary and secondary transfer units have recently been changed. Any ideas guys? thanks
  • spanky
    • Sep 2012
    • 468
    Re: L4-12 sharp mxc 310
    Check that you don't have a problem with the fuser unit or the fuser drive, a fuser that stalls when it gets hot can cause this.
    Clean the front resist sensor and do the calibrations with the jig.
    If this does not fix the problem then replace the resist sensor unit.
    • DavePo
      • Jul 2008
      • 305
      Replace the Resist Sensor unit. CHLDZ2001FC31
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • Akitu
          Legendary Frost Spec Tech
          • Oct 2010
          • 2595
          There was a firmware update (v4 I believe) that aided in preventing L4-12 codes by increasing fault tolerance. Update your firmware!
          • copyguy1
            • Jul 2011
            • 142
            Also there is a new clutch for the drive unit. Check bulletins.
