Sharp mx 362
  • Saji
    • May 2010
    • 97
    Sharp mx 362
    sharp Mx 362 showing Error 7-21,wht could be the problem, how to reset it pls help.
    thanks in advance
  • muthuk7
    • Aug 2010
    • 57
    Re: Sharp mx 362
    hi mr.saji,
    if your machine model should be MX-M362N and the error code might be E7-21 the remedy is
    Use SIM61-1 to check the operation of the LSU.
    Check the PWB and connection of the harness in the
    LSU.
    Replace the LSU.
    • Saji
      • May 2010
      • 97
      Re: Sharp mx 362
      Thank you so much...
