MXM 363n gray background
Re: MXM 363n gray background
BilComment
KJaques
Hi,
have you tried doing a forced process control, sim 44-06 I think.
had similar issue recently and this did the trick!
Good luckComment
Model was known to dump toner upon cartridge insertion or moving machine. Can determine by running Sim 25-1. Value will be very low like 30-60. Can detone by running Sim 7 with dv check disabled and make 50-100 skyshots.Comment
Install dv, run 25-2, and install toner. We put the toner that has been used for adjusting and testing in the box and ship the machine without the toner installed.
We do this for all the newer machines except the Dragon types and the Andromeda types."You can't trust your eyes, if your mind is out of focus" --Comment
