No network function on MX-700n
  • gfady1
    • 16
    Dear all
    I've got sharp MX700n and it was working perfect with both USB and network
    but suddenly the network function stopped working while the USB still working.. even the icons for setting the IP disappeared from the touch panel
    Any help ..
    Thanks in advance
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: No network function on MX-700n
    Usually if network printing stops working suddenly, it's either because another device on the network attempted to pull the same IP address from DHCP and you now have a duplicate, else it wasn't properly set up and was coasting off DHCP, the DHCP lease expired and the equipment has a new IP address.
    • lky1978
      • Mar 2009
      • 482
      Try to pull out the nic card, clean the nic connector and put it back.
      Tried many units ar-m550n in field.
      • CorbinDallas
        • Mar 2012
        • 56
        Did you resolve this? Does or did the model display on the 22-6 print as MX-M700U by chance?
