sharp base laser code no ops panel
  • d.tyler45
    • Jul 2025
    [Error Code] sharp base laser code no ops panel
    I have a IM 3510 used with no scanner and I want to reset the laser code from the small interface . I just need it for printing only. Thanks, David
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: sharp base laser code no ops panel
    If you're getting a laser code, you might be able to reset it, but it will need to be replaced soon.
    I have instructions to clear code for the Sharp printer, not sure if it will work on the IM machine.
    • d.tyler45
      same machine, I just never had to do it through the small panel on the machine itself
      • ZOOTECH
        • 3375
        To access Diag mode:
        press and hold the Menu and OK key while powering up;
        display should read - PCU DIAG MODE;
        press the Menu key about 17 times (depending on frimwar level), display should read Trouble Cancel;
        press the OK key, display should read Trouble Cancel E_Trouble No;
        press the Arrow key until display reads Trouble Cancel E_Trouble Yes;
        press the OK key, Data light should blink while cancelling trouble;
        power off/on - trouble code should be cleared except for a hard failure, again the LSU is not going to last long.
        Good luck
        • lky1978
          • Mar 2009
          • 483
          all codes can reset by off-on operation. Except error code that start with H?-0? or U?-0?
          • d.tyler45
            [QUOTE=lky1978;400864]all codes can reset by off-on operation. Except error code that start with H?-0? or U?-0? true, but this does not show how to reset from small interface. I got it from another user. Thanks
