Mx2310 A3 internal tray problem
  • ash_572
    • Oct 2008
    • 523
    2310u with a standard internal tray.
    A3 is curling over as it comes out on to the exit tray and the trail edge is not always moving away from the white exit rollers. This happens on multiple copies a3 only. The leading edge hits the tray and curls over.
    I removed the the exit actuator and the paper full sensor with no effect. Fresh paper is used and the exit section rollers are cleaned
    wouldnt be suprised if this is a well known issue
    any ideas what it is??
  • ash_572
    • Oct 2008
    • 523
    Re: Mx2310 A3 internal tray problem
    I'm guessing no one has any idea on this fault??
    • harleyrider
      • Oct 2011
      • 348
      There ia a bulletin #MFP-TB-525 you might try.
      • ash_572
        • Oct 2008
        • 523
        Do u mind uploading the bulletin here? I would appreciate it. Thanks
        • mojorolla
          The Wolf
          • 2626
          Without an internal finisher, there should be a large wishbone shaped arm that hangs at exit to force the paper flat into the tray.
          • ash_572
            • Oct 2008
            • 523
            The wish bone actuator is on and still curling the paper over. I removed the exit actuator and still having the same problem
            • Akitu
              Legendary Frost Spec Tech
              • Oct 2010
              • 2595
              So you say your paper is curling when exiting the tray, or when passing the fuser and exiting into the center tray?
              If the former, take a look at your tray lift motor to make sure it's lifting the paper completely. If the latter - have you done a panic stop to determine what the paper looks like throughout the print process?
              • faxman28
                • 435
                bulletin is attached. settings are for U.S. have you flipped the paper over in the tray ? have you tried different brand of A3 paper ? paper may have to much (natural) curl in it . Or paper may to thin or not stiff enough Usually in the U.S. I see this in humid times and fuser is to hot. flipping paper over and lowering fuser temp helps.
                • Jhonjon
                  • Sep 2013
                  • 208
                  Suggestion, try to test an A3 paper to bypass or the first tray. If the same problem occures maybe you can try another brand or weight of paper.
                  • ash_572
                    • Oct 2008
                    • 523
                    Basically when the a3 is feeding out of the exit section of the machine onto the internal tray, the white roller doesn't seem to flick the rear end of the paper on to the internal tray.
                    MRI tried it from a different tray still the same.
                    Same brand paper is used as before and worked fine in the past.
                    • ash_572
                      • Oct 2008
                      • 523
                      just uploaded this picture. give you all a better idea
                      • Akitu
                        • Oct 2010
                        • 2595
                        Try adjusting your paper exit motor speed in sim 48-6.
                        • ash_572
                          • Oct 2008
                          • 523
                          Today the fixing paper holder was replaced that hold the white fixing arm with no effect. Every 3 or 4 copies the a3 is turning over on to the tu12 tray. Ant ideas?
                          • Akitu
                            • Oct 2010
                            • 2595
                            • ash_572
                              • Oct 2008
                              • 523
                              Will that not affect the timing of the sensors when doing multiple prints??
