MX-RP11 skewing issues
  • Hansen88
    • 1085
    Hello, we have a few of these feeders on MX-M503s and I am having a skewing problem. I went through all the feeder set up adjustments with the hinge adjustments and such. In general they are spot on with all alignment aspects. The problem is if you run 20 or so sheets through two or three will get skewed just enough to leave a line on the edge of the paper. I could get rid of the line if I increased the edge erase but that does nothing for the real cause which is the skewing.I believe the feeders are aligned properly but dont know what else might cause the intermitant skewing.I would welcome any and all suggestions. Thanks
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2595
    Re: MX-RP11 skewing issues
    Could be paper at fault or guides set too tightly. What have you tried so far? Which adjustments specifically?
