MXM450n dev pulling
  • foudl
    • Mar 2010
    • 138
    [Electrical] MXM450n dev pulling
    The dev is pullling out , i changed the drum assembly (whole unit+drum+Main charge),tranfert unit, problem persist, contacts on the left door seems clean as well as ground for drum.
    Advice is welcome.
  • Jhonjon
    • Sep 2013
    • 208
    Re: MXM450n dev pulling
    Try to check if the Developer is sticking on the drum if so, Check the bias of the DV or test other DV unit. If you have HV try to test it also.
    • foudl
      • Mar 2010
      • 138
      Yes there is a slice of dev on the drum (inboard),regarding
      Hv unit is it hard to replace?
      • Jhonjon
        • Sep 2013
        • 208
        Hope this will help if it is hard to remove?! No pain no gain...
        • bilyahn
          • Dec 2006
          • 1470
          It's not as hard as some of the newer series machines power supplies. But it's behind another board as the illustration shows.
          Good luck.
          Bil
