This problem only seems to occur on plain 8.5 X 11, 20lb paper. It happens on the first side (CCD), but I did not see it on 2nd side (CIS). On the attachment, you will see the lines are not straight on the front or rear edge and if you look into the wording it looks like the distortion goes off into an angle in all 4 corners
I have not tried scanning 8.5 X 14 or 11 X 17.
I tried heavier stock once or twice and seemed fine.
The feed rollers are good, I replaced the transport rollers before and after the slit glass. Replaced the slit glass unit for the optics and CIS.
I am thinking it is something stupid, but have not figured it out yet.
