Mx-3140 doc feeder jamming
  • Daveyboy
    • Feb 2011
    • 18
    [Jamming] Mx-3140 doc feeder jamming
    Hi All,
    Can you advise?
    i have a mx-314O and the doc feeder jams at sppd2 not reached.
    the sensors all work and when I do an ageing test it works to.
    HELP!!
    Regards,
    dave.
  • divad2k1
    • Sep 2010
    • 147
    Re: Mx-3140 doc feeder jamming
    Your sppd2 sensor can still be the problem. Had similar issue this week.
    • MHeon71
      • Oct 2008
      • 489
      Sensor is probably the problem. I have not seen my issues in that machine yet or in DF, but I have seen it in MX-M503 and MX-2640 in the paper feed units of newer machines. Take a look at bulletin -MFP-TB-822R3. If you think this is the problem, you may want to order extra and replace the sensors that you have to go by to get to SPPD2 sensor.
      • copytechonline
        • Nov 2011
        • 40
        Replace SPPD2 ive had 3 ADF's with similar jamming probs in the last 4 weeks all new models and all with SPPD2 and SPPD3 problems all turned out to be the sensor, and they are the same sensor, im wondering if Sharp have found a cheaper supplier as we never had so many probs with doc feeds on new kit before.
