New Sharp MX-M753U Print Problem
  • fbkhan3
    • May 2012
    • 421
    Hi,hope you all doing great!
    (PRINTER EXPANSION KIT MX-PB13 ) is available but Machine will not except the Product key (DB15130145) written on the pamphlet.
    I had to look for this mentioned above model which is installed and working as copier but it won't print,they have 4 of them out of box and all have the same issue,Add printer will detect the printer,shows online after installation and drivers are also properly installed but sent print will lost.
    I also tried it with Laptop and cross over but same result,I'm also able to browse the web page and make settings.
    I would really appreciate your help regarding this issue!
    Regard's
  • Akitu
    Legendary Frost Spec Tech
    • Oct 2010
    • 2596
    Re: New Sharp MX-M753U Print Problem
    Regard's
    I've not converted a U unit so forgive me if I'm wrong, but is this not one of the products that has to be registered on the japanese website before it will be usable on the machine?
    • bilyahn
      • Dec 2006
      • 1465
      DB15130145 is the application number that used in conjunction with the machines serial number using the website mentioned by Akitu will get you the 20 digit product key. Pretty straight forward install once you have the correct information.
      Good luck.
      Bil
      • fbkhan3
        • May 2012
        • 421
        Thank you so much for this information ,
        Would you be kind enough to write down that website.
        Really Appreciated!
        Regards
        • ZOOTECH
          Senior member of CRS
          • 3378
          Really Appreciated!
          Regards
          Sharp's versatile lineup of digital MFPs offers secure, high-quality, environment-friendly document solutions that keep pace with your growing business.
          • harleyrider
            • Oct 2011
            • 348
            good luck
            • ZOOTECH
              • 3378
              Originally posted by harleyrider
              good luck
              He'll need it without passwords and credentials from an authorized dealer.
              He could contact a dealer and with the application #, s/n, and model # they could acquire the product key for him (and maybe charge a small fee).
              • fbkhan3
                • May 2012
                • 421
                Thanks a bunch for the information,i'll talk to dealer if he can get me the product key!
                Best Regards
                • fbkhan3
                  • May 2012
                  • 421
                  Re: New Sharp MX-M753U Print Problem (Solved)
                  Thanks everyone for your kind support..
                  Product key worked and bingo ......Machine is working well as Printer now.
                  Regards
