Sharp MX 2314
  • mabro1974
    • Feb 2013
    • 39
    Sharp MX 2314
    Just wondered if anyone could help me,i am trying to set up banner printing on a MX 2314 but cannot see any options in system / tray settings and nothing in simulation mode .
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp MX 2314
    I don't think you can do it. 12X18 appears to be the largest it will print on.
    Good luck.
    Bil
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: Sharp MX 2314
      You will need to install the MX-LT10 option.
      • Michmich123
        • Nov 2013
        • 24
        Re: Sharp MX 2314
        Change the Setting of Long size in SIM 26-50 .
        Then you can change the size for Bypass Format to max 1200x297 . This size can only use for Print .not for copy !
        the bannertray is Nice to have , but Not important . wrap the Banner and insert in Bypass .
        in the printerdriver now can set this in in user def. paper size.
        Have fun
        i try'ed this at home .
        michmich 123
        • smiler6786
          Re: Sharp MX 2314
          Have fun
          michmich 123
          I've done all this but my printer driver won't let me alter the custom size to 1200 long. It maxes out at 431.8. Help!
          • Akitu
            Legendary Frost Spec Tech
            • Oct 2010
            • 2595
            Re: Sharp MX 2314
            You might need to enable long paper support in sims. If you don't have sim access, contact your local Sharp representative.
            • mojorolla
              The Wolf
              • 2627
              Re: Sharp MX 2314
              This feature is for PCL drivers only. It is not available using the PS driver.
              Also, you must select Long Paper to adjust the range up to 1200.
