Sharp 450 dirties copies and print
  • akbareshghi
    • Sep 2010
    • 261
    my dv powder is finishing to the end of life and my texts are printed relatively pale but without any copy quality (no line or dirties or spot)
    then I executing the code 25 then 01 manual
    after restarting the machine the spot appeared on the following picture is showed up on the copies
    then I replace the DV powder with new one
    executing 25 # 2 based on the instruction of service manual
    all thing ok except copy quality and the one line excess and some dirties was appeared on the copies
    my pale copying was eliminated with replace dv powder
    I change blade of drum and cleaning some part of drum unit
    but above problem still exist
    it must be noted that some toner leaked and collected on one side of drum unit and poured to down
    thanks a lot for your suggested solution and troobleshooting bad copy quality?
    Color printing with lowest cost per page is my love.
