h4-01 on a mx-m550
  • ssbmi
    • Oct 2013
    • 32
    [Error Code] h4-01 on a mx-m550
    I got a mx-m550, h4-01 code. changed out fuser with a rebuilt fuser. same code next day. checked fans both working. going to boards next. or is there something I should be doing first? was there a tech tip/bulletin that I missed on that code?
  • MHeon71
    • Oct 2008
    • 489
    Re: h4-01 on a mx-m550
    H4-01 is low temperature. I would check thermosters and thermostats. Check lamps with TC 5-2, they should blink. According to manual, the interlock switch could cause problem.
    • divad2k1
      • Sep 2010
      • 147
      Do you know if your customer was printing /copying on heavy paper before the code showed up ?
      • ssbmi
        • Oct 2013
        • 32
        for the first code customer said they did heavy paper, after I changed fuser. 2nd code the next day customer said it was just plain paper... and that was with the rebuilt fuser.
        • walterman
          • 196
          Have you checked the ac voltage to the mfp?
          • ssbmi
            • Oct 2013
            • 32
            not yet, this problem has now turned into a intermitted problem since I last reset the thermostat, and cleared the code. I haven't been called back. But since I haven't fixed anything. its still open to me, might be a case of AM/FM
            • faxman28
              • 435
              the code is for low temp, if you have to reset the thermostat, the thermostat is probably faulty(normally when thermostat pops there should an Hxxx error for high temp). have had this issue several times, different fixes though , 1: take washers from thermostat mounting screws and put under thermostat to move it away from heat roller(metal plate that thermo mounts to maybe deformed.) 2: replace heat lamps (especially if they have rings or discoloration) 3: replace thermistors , 4:replace thermostat. from experience I usually do 1,2,and 3 together and the intermittent h4-01 go away.
