Sharp Mx 2310 showing error: data sub c f head 20 what could wrong and is the solutn
  • bisiawoeyo
    • Dec 2007
    • 65
  • MHeon71
    • Oct 2008
    • 489
    Re: Sharp Mx 2310 showing error: data sub c f head 20 what could wrong and is the so
    No idea, when is it happening? Looks like an error that presents itself during calibration or some kind of adjustment. During adjustments, scanning, copying, faxing?
    • bilyahn
      • Dec 2006
      • 1470
      It is a calibration error. What have you done and what were you doing? A lot of "things" can contribute to this happening. Some more information might be helpful.
      Good luck.
      Bil
      • spanky
        • Sep 2012
        • 468
        Go to sim 50-20 and set all of the color adjustments to the default settings and then run the 50-22 again.
        • faxman28
          • 435
          error with laser alignment, try these steps to correct
          TT-090513_1
          Bulletin: Data_SUB_K_F_1ST_ 10 Error
          Factory Number: TT-090513_1
          Solution Summary: If this error occurs when running Simulation 50-22, use the below steps to recover. This Information supersedes TT-20398.
          Creation Date: 9/5/2013
          Expiration Date: 1/1/2030
          Models: MX2310U, MX2610N, MX3110N, MX3610N, MX4110N, MX4111N, MX5110N, MX5111N
          Priority/severity: Medium
          Description: If this error occurs when running Simulation 50-22, use the below steps to recover.
          1. In Simulation 50-20 enter default values (100) for A through I, then press Execute.
          2. Then run Simulation 50-22 and adjust each screw for each color as directed by the Simulation
          results. When turning the screws be sure to use clicks not turns.
          If problems continue replace the laser unit.
          • danceswrabbit
            • Dec 2013
            • 65
            I had something like this on a mx3610 . The customer had moved machine and new outlet was not up to the task. ( voltage drops of 10 to 15 volts) Machine had pulled most of the black developer.
            • mojorolla
              The Wolf
              • 2603
              SIM 50-10, value A (blk mag) set to default of 110, then attempt 50-22 again.
