Address Book Size
  • teklife256
    • Sep 2012
    • 164
    #16
    Re: Address Book Size
    Certainly glad to hear that I don't need additional hardware to make the pc-fax work. Now only if I knew how to use it...... After downloading the drivers Im not sure how to send a fax from the pc. Is there a particular application that I need?
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      #17
      Install the driver as you would any other, and print as you would any other print job. Select the fax number from the address book or enter it manually; the copier does the rest.
      • ZOOTECH
        Senior member of CRS
        • 3375
        #18
        From what I remember, you have to set up a printer PC FAX port. To send, you select print (to that port),
        enter the fax number and cover sheet, and send.
        Dam you Ruben.
        • teklife256
          • Sep 2012
          • 164
          #19
          Success. Faxed using the pc-fax to several numbers. The goal is to fax some 10,000 fax numbers. Perhaps 10 phone books of 1000 numbers would meet the total. My next question is at which point would the workstation become unstable with all these entries? Im hearing that the pc-fax application becomes very slow at just 500 entries. Anyone with experience in something like this??
          • faxman28
            • 436
            #20
            Ah spam the old fashioned way, if your costumer wants to fax 10,000 locations at one time a fax server board and software maybe better way to go. I would think the copier would be tied up for a few days trying to send to 10,000 locations.
