PPD2 error MXM452
  • andyt2107
    • Jun 2013
    • 18
    PPD2 error MXM452
    I have a copier that has PPD2 errors from all trays i have replaced the sensor which worked for about a week i tested the sensor which was working anybody else know a fix or do i put a new paper feed assy in.
    Cheers
  • bilyahn
    • Dec 2006
    • 1470
    Re: PPD2 error MXM452
    Check the clutch on the feed assembly prior to the PS unit. Have had issues with these on the MXM453 series. There is a distinctive noise when this is happening, hard to describe but sounds like paperfeed is dragging compared to normal.
    Good luck.
    Bil
    • skookumchuck
      • Feb 2012
      • 62
      Check Sharp tech bulletin MFP-TB-822R3. I don't see your model listed but there a lot of machines on it. I have had to replace a number of switches in the document feeder on a couple of machines.
