Hi I was wondering how do I get rid of the service wrench on a Ar-M205? Also where can I buy parts for this particular machine, I live in Minnesota.
The wrench means it needs preventative maintenance.
I recommend calling a tech to determine what parts are needed depending on the # of copies.
The only way to get rid of the wrench is in service mode.
Leave this to the tech, you could end up with an expensive boat anchor if not used properly.
