MX-M314N w/ MX-FX11 fax receive error
  • Ingersoll
    • Nov 2008
    • 74
    Customer reports a fax receive error of FAIL05 and FAIL07 but I cannot find any information in the service manual which describes this code. Google searching on Sharp website does not show any results either.
    Has anyone seen this or knows what it means?
  • draph
    • 132
    Re: MX-M314N w/ MX-FX11 fax receive error
    Haven't seen it but I would be looking for a code of that nature in the operators manual. Not the service manual or web site.
    • Ingersoll
      • Nov 2008
      • 74
      Yes the Op Guide says this but does not list any codes
      Pg 5-111 of Op Guide
      FAIL xx (xxxx) The transaction failed due to a communication error.
      First 2 digits of communication error number: Error code from 00 to 99.
      Last 4 digits of communication error number: Code for use by service technicians.
      The Service Manual gives codes but not informing about the FAIL part of the error
      MX-M264U TROUBLESHOOTING 7 – 24
      1) Communication report main code
      CAUTION: For report codes 16 – 31, V.34 MODE COMMUNICATION.
      Report Final receive signal Final receive signal
      code (Send side) (Receive side)
      5 PIP, PIN MPS
      7 No signal, DCN DCN
      I thought the SM might have the codes and it did, but doesn't illuminate the darkness of confusion.
