MX-5001N Lost Web page password
  • Jaws
    • Oct 2007
    • 236
    Somehow the web page password has been changed. And themachine has a security data kit inside (MX-FR11U). So, I can't do a 24-30 or24-31. Read there might be some dip switches I could turn on and force a reset,but I could not locate them. Called sharp and they said there is no way to recoverthe password. They said I couldn't even take the MX-FR11U out and replace themwith factory chips to get it back. I upgraded the firmware, but it did not help.
    Anybody got any suggestions????
    All comments are welcome, good, bad, even sarcastic.
    Sad thing is, I think the customer changed it and won't admit it. Now they want us to replace the machine.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MX-5001N Lost Web page password
    Contact any previous owners of the machine, they might have a record of it or use the same password on every machine.
    • ZOOTECH
      Senior member of CRS
      • 3375
      Are you able to login to the admin settings at the copier? I haven't had to try this (thankfully) yet, but maybe a NIC reset would put the admin password back to default - it couldn't hurt and settings could easily be returned (this is assuming you can access admin settings at the copier). I have not seen the little switches on the MFP pwb that's located on the right side, only on the left side pwb.
      • MattL
        • Apr 2012
        • 97
        Have you tried a blank password, we found that with some machines that is what the password ended up as.
        Failing that there is a topic on here on how to reset the passwords, move one of the dip switches and it works too.
        • CorbinDallas
          • Mar 2012
          • 56
          Replace the data security kit flash roms with normal roms. Then you can do 24-30. Then reinstall the DSK roms.
          • ren2003
            pswd reset w/security kits
            Only way to reset a sharp MFP password that has a data security kit is to run 62-1 hdd format, purpose for the security kit is to protect data written on to the disk. Once formatted, usually pswd will default back to default. You can also run 67-70 to clear out NIC settings, this wipes all configurations including dns and smtp ect... if being used.
            • Jaws
              • Oct 2007
              • 236
              Hard drive format did the trick, thanks ren2003. Takes about 30 to 40 minutes
              • Wind Cool
                • May 2014
                • 82
                Have you try using Supervisor to login ?
                • ZOOTECH
                  • 3375
                  Did you read his last post???
                  • mojorolla
                    The Wolf
                    • 2627
                    Just did this 2 weeks ago on a MX-M623 with DSK.
                    Worked like a charm!
                    • pmehreteab
                      If you reset the NIC card to factory default, then you could log on the web page using the default password,which is "admin"
                      • harleyrider
                        • Oct 2011
                        • 348
                        Thread is over a year old.
                        • sharphead
                          • Aug 2009
                          • 285
                          Its not anymore
