Sharp AR-M550 error code E7-02
  • copyplus
    • Jul 2009
    • 100
    [Error Code] Sharp AR-M550 error code E7-02
    My machine is giving me error code E7-02. I need help to fix this problem. thanks
  • divad2k1
    • Sep 2010
    • 147
    Re: Sharp AR-M550 error code E7-02
    Replace the lsu.
    • copyplus
      • Jul 2009
      • 100
      This is not a constant problem. The machine works fine but sometime it gives that code and stops working and next day it will turn on fine. Is there any code that needs such as 61-1 or 61-2 needs to be run to get rid of this problem. thanks
      • harleyrider
        • Oct 2011
        • 348
        lsu is where I would start.
        • lky1978
          • Mar 2009
          • 483
          try to open the lsu unit, clean all mirrors, glasses. Maybe mirrors/glasses dusty and block the laser beam when the beam point to the laser synchronize detector.
          • copyplus
            • Jul 2009
            • 100
            I tried to clean the mirrors and checked for any loose connection. Still having the same problem. Is someone know if anyone has a used lsu that I can buy. thanks
            • copyplus
              • Jul 2009
              • 100
              After opening the unit and cleaning the mirrors and checking the wires, installed back and the code E7-02 is constant now. Prior to opening the unit it was working on and off. Maybe there is something that needs to be checked. thanks
              • faxman28
                • 435
                Time to replace the LSU , either laser diode or beam detect sensor failed or was nocked out of place. adjusting/replacing beam detect sensor needs precise alignment which cannot be done in field same for laser diode.
                • copyplus
                  • Jul 2009
                  • 100
                  What is the difference between AR-M550N and AR-550U? Can I use parts from AR-550U to replace in AR-M550N including LSU? thanks
                  • harleyrider
                    • Oct 2011
                    • 348
                    as long as they are both 550's they have the same lsu. I asume they are both arm.
                    • Akitu
                      Legendary Frost Spec Tech
                      • Oct 2010
                      • 2595
                      The difference between an N version and a U version is the NIC and HDD. All other parts are the same, you can take an LSU from 550U to replace LSU in 550N.
                      • copyplus
                        • Jul 2009
                        • 100
                        I have found Sharp AR550U. The machine has an error code F2-31. This code is related to the PCU. Can I use LSU from this machine to replace in my Sharp AR-550N. Can that error code create a problem and effect the LSU? please advise. thanks
                        • Akitu
                          • Oct 2010
                          • 2595
                          The F2 code will not affect the laser. Those are usually triggered when the waste toner fills up before the toner bottle is emptied and the drum augur can not turn properly, either stalling or seizing altogether. Your laser should remain unaffected.
                          • Virus2007
                            Hi;
                            regarding this error can be resolved tuning the laser in the blue screws very carefully with the help of code 61-01 and 02 ng ... ok, but the best and replace full lsu.
                            • copyplus
                              • Jul 2009
                              • 100
                              Originally posted by Virus2007
                              Hi;
                              Would you kindly elaborate this process in little detail? I will appreciate your assistance.
