MX4112 E7-95 Error Printer DIMM
  • techspec
    • Dec 2008
    • 128
    Hi All
    Currently experiencing an issue with a MX4112 which is displaying a E7-95 Printer DIMM error.
    Printer DIMM has been replaced along with the MFPC PWB and fault is still showing.
    Anyone came across this fault and can possibly shine a light and point in the right direction?
    The device uses Equitrac and DSK.
    Thanks in advance.
  • techspec
    • Dec 2008
    • 128
    Re: MX4112 E7-95 Error Printer DIMM
    Originally posted by JustManuals.com
    This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
    Paul@justmanuals.com
    Thanks Paul but I'm in receipt off manuals and access to Sharp technical pages.
    • brokey
      • Oct 2011
      • 22
      Had the same problem with a MX-2610N, turned out to be EEPROMS. Had to send them to Sharp along with a new set for reprogramming
      • mojorolla
        The Wolf
        • 2630
        I remember a bulletin regarding DSK and Equitrac but cannot find it on the site. DSK firmware version 8 addressed an issue with Equitrac and an issue with E7-95.
        You could clone the machine and run SIM 67-17 and flush the print memory. This SIM will wipe SMTP settings, print port settings , and domain name so make sure you backup the data first.
        • faxman28
          • 435
          mfp-tb-743 for mxfr33u, there are othe bulletins/firmware for machine without security kit also.
          • techspec
            • Dec 2008
            • 128
            Good shout faxman.
            Can't find the bulletin on Sharps UK site. Can you post the bulletin on here?
            • faxman28
              • 435
              [QUOTE=techspec;419522]Good shout faxman.
              CCE1154-MFP-TB-743.pdf
              the fw version is 0800,but there is new ver 0810 don't know if this is same in UK. The fw has a few fixes in it and there is one that says when printing pdf E7-95 errors have been corrected. Also don't know if you can just replace memory or hdd when a DSK is installed. I would think there would some type of protection against that.
              • Akitu
                Legendary Frost Spec Tech
                • Oct 2010
                • 2595
                [QUOTE=faxman28;419585]
                HDD can be replaced, just has to be formatted and have DSK firmware installed with covers open.
                RAM can be replaced freely.
                ROM can not be replaced.
