AR M450
  • swagreis
    • Jun 2008
    • 92
    AR M450
    i have a probelm in laser unit is L6-10
    is there any solution to solve it without changing laser motor?
    is there anyway to prevent it?
    i need parts guide of AR-M450
  • mtech
    • Mar 2007
    • 307
    I do not think you can replace just the motor. You need to replace the whole laser unit. Excessive heat can cause the unit to fail prematurely. The M350/450 has a lot of cooling issues. Mostly in the delivery turn unit area. The part number for the LSU on a M450 is DUNT-7093DS11.
    • johnbla
      • Apr 2005
      • 94
      Replace the PolyMotor, it IS available as a service part.
      regards
      John
      sigpic
      " The Game never ends..When your whole World depends..On the Turn of a Friendly Card..."
      • mickspace
        • May 2008
        • 22
        try simulation code 14 a few times.. if it does not work, you get to replace the laser unit... yes the Polygon motor is a service part, if you know what you are doing.. which I assume you do not after reading the question .. the laser Unit is easy to get to and replace.. The poly motor is a bit more of a challenge and has to be damn near perfect..
