Black lines on prints...
+ More Options
Posts
  • mahix
    • Feb 2014
    • 18
    #16
    Re: Black lines on prints...
    Originally posted by ZOOTECH
    If any drum exchange, use the less used one - that is the yellow one, the output would be less noticeable than with the cyan or magenta. This is for testing and a quick fix until you return with the proper supplies.
    Damn, I' really getting slow or I should refresh more often.
    Yes. I understand that it is for just checking the problem is from Drum or not and thanks a lot for suggesting yellow drum instead of M. i will let you know as soon as i could check this issue.
    • ntbann
      • Jan 2012
      • 626
      #17
      The charge corona is bad. Replace with a new one. This is a common problem with sharp color machines.
      • hellcat
        • Jan 2012
        • 124
        #18
        That is 100% a Charge Grid Problem.
        Simply take out of the charge grid above the cleaning K Blade and Remove the grid part using a small flat tipped screw driver. Soak the grid in simple green or other mild cleaner. Also take a small towel and clean the small spikes inside the charge unit. Put it all back together and you should have nice copies again. Doubtful you actually need to replace the grid unless its really really dirty. This grid will usually be a light to dark green color it should be silver/blackish when your done cleaning If lines persist clean it again or replace it. Take a piece of paper and line it up to the grid where the lines are is where it is dirtiest.
        • maddog3k
          • Dec 2010
          • 3
          #19
          that is correct its the charge corona unit in the drum unit all you have to do is clean it and that should take care of it
          • mahix
            • Feb 2014
            • 18
            #20
            Ah, right to left - those are lines then in the direction of the paper travel.
            Lines that are perpendicular to the direction of paper travel are called front to rear.
            I like the above post about switching the black drum unit with one of the colors to help isolate the trouble.
            HI
            i have been replaced the Yellow Drum with Black one and problem has been solved. but I have been heard that I need to adjust the drum after replacing. I have been checked the service manual but i didn't find sth that i need. kindly advice to me in this regard.
            thanks
            • walterman
              • 196
              #21
              The best way I have found to adjust the drum registration is by placing my face on the glass, with eyes wide- open, and pressing the color print button. If at first this does not work, repeat the process several times unit you have achieved optimum color performance. I have noticed one side effect to this method of adjusting the color alignment, I tend to walk around half the day with black spots when I blink.
