MX-C401 duplex jams
  • Old Sergeant
    • 16
    [Jamming] MX-C401 duplex jams
    I have a Sharp MX-C401 with a MX-FN12 finisher that jams every duplex at the finisher rollers after printing one side. It will duplex fine with the finisher removed. Replaced both POD1 and POD2 in duplex without effect. I'm thinking the sensor in the finisher might be bad but can't find where this sensor is involved with duplexing or understand why one sided copying works with the finisher if this sensor is bad. Also, if it is the sensor in the finisher, I could use the part number. Any ideas would be appreciated.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: MX-C401 duplex jams
    Check the operation of the FPGS solenoid and the paper entry guide in the finisher.
    • hellcat
      • Jan 2012
      • 123
      is this a new install or a machine in service awhile?
      If new make sure the finisher plate guide is installed correctly as there is a sensor there that tells it when it exits the machine and goes into the finisher, Ill check my book in the morning and post the actual diagram.
      • Old Sergeant
        • 16
        I'm not sure if it's a new finisher. It was moved into my area and wasn't duplexing when it got there. But the finisher does sort and staple, which is what has me confused as that indicates the sensors and motors are working in the finisher yet it won't duplex with the finisher attached but will with the finisher removed.
        • Old Sergeant
          • 16
          Sorry, I forgot to mention I checked the solenoid operation and it does seem to be working.
          • faxman28
            • 436
            check bulletin
