Sharp MX-M450N
  • lenovos
    • Oct 2012
    • 140
    [Error Code] Sharp MX-M450N
    Service call said that copier had U2-22 ERROR. I explained how to reset code over phone. Machine reset but code returned as soon as copier started to print.
    I had customer unplug net cable and copier worked fine. I then went to look at copier. The problem turned out to be a corrupted print job. After clearing cue from computer problem was solved.
