MX-M 950 F1-15 code
  • jrob416
    • May 2011
    • 112
    [Error Code] MX-M 950 F1-15 code
    I have a MX M950 that will throw the occasional F1-15 error code. I know this is related to the finisher, and have cleaned all sensors on said finisher. Also re-seated the connectors to finisher main board( just for giggles, you never know) and checked main board on main body to be on safe side. The machine will jam at fuser exit and throw the code after clearing jam. I am stumped and would appreciate any ideas. Thank you.
  • sharpie
    • Feb 2011
    • 182
    Re: MX-M 950 F1-15 code
    Sharp says that the 256Mb DIMM on the MFP board can cause this error but I suspect that the tray lift motor is the culprit. They have issued a specified life cycle for them at Sharp so I would say they are having issues with this component and are implementing the CYA protocol.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Any kind of resistance placed on these finisher motors damages them. You may need to replace the motor.
      • mojorolla
        The Wolf
        • 2626
        Agree with above; replace the tray lift motors. We are constantly moving garbage cans and recycle bins under the finisher trays when this code appears. A month later, same garbage can under the same tray....customers....
        Also check for a frame screw in the track that has backed itself out. I have seen this at least 3 times.
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          Offset tray lift motor should be replaced every 1000k as part of routine maintenance part number 0PPAX050277
          Hope this helps.
          Networking skills are advantageous but use of a 3m vacuum cleaner is essential
