power switch
  • ssbmi
    • Oct 2013
    • 32
    [Misc] power switch
    I am working on a MX-M 700n. My problem is mfp will not power back on once it has been turned off with the power switch(outside switch). Unless reset using the main power switch(inside switch) first.
    Things I have done so far : Changed out both power switches. Inside, and outside, Changed out Sub power supply pwb. Changed out AC pwb, and DC power supply pwb.
    Any information will be looked into. thank you in advance.
  • igi
    • 1507
    Re: power switch
    hi try to borrow a whole display panel from another machine to eliminate
    • ssbmi
      • Oct 2013
      • 32
      Re: power switch
      Thanks for the idea.. I tried the display panel from a mx-m 550. no joy, problem still the same.
      • igi
        • 1507
        Re: power switch
        ok I thing you narrowed it down to (scanner control pwb)
        • ssbmi
          • Oct 2013
          • 32
          Re: power switch
          ok, changed out scanner control board, also changed out pcu pwb. Still no change. I have no direction or idea where to go next. ;(
          ANY HELP, anybody have this problem before.?
          • igi
            • 1507
            Re: power switch
            ok now you have to take a fluke(meter)and start measuring voltages.
            and resistance in the harness
